Netflix Won't Stream on Samsung TV with Three 5G Broadband
thus78
I recently bought Three 5G broadband and connected my Samsung Smart TV to it. The TV shows that it is connected to the internet, and Amazon Prime streams content without any issues. However, when I try to watch Netflix, the videos either stay at 0% or get stuck at 25% and don't play. I have tried troubleshooting by turning off the TV and router, waiting for 30 seconds, and restarting Netflix, but the problem persists. When I switch back to my previous internet provider's wireless connection, both Netflix and Amazon Prime work perfectly. What could be blocking Netflix from streaming content on my new Three 5G broadband connection?
  • 5G
3 REPLIES 3
Hi @thus78,
This sounds a bit like the issues reported in ZTE 5G ROUTER SETTINGS so changing your TV's DNS settings to 8.8.8.8 may help with this one.
Some community members have also found setting their APN to a manual profile for IPv4 only has also helped with this similar issues as described in this thread: FYI : IPv6 Prevented VPN Connection
London156
Hello, I have had this issue for the past 5 months and been all around the houses with Netflix, Samsung & Three. I just changed the DNS to the numbers above and my Netflix is finally working!!
thank you so much for sharing
MZone
Maestro
Call 333 option 4 option 3 and option 3 to discuss your issue with tech support.
Type a product name
