NR5103E won't connect to 5G
EddersD
I just set up my new router and I can't connect to 5G, I seem to be limited to LTE only. My phone connects without issue.
Firmware is V1.00(ACBJ.0)b9 and I've been reading about b10 solving some issues (although those people were coming from b8). Any way I can force this update? I've tried looking for the firmware download in Zyxel's website with no luck
40 REPLIES 40
stephen
TOP TIP ABOVE!! replacement arrived 4g only, followed your how to and viola 5g full bars, fingers crossed this box lasts more than 2 days.
stephen
just noticed router has upgraded to b12 so i turned auto on in band management as described above and 5G 100% in auto setting. peace.
Excellent, thanks @cmcquillan. @stephen, let us know how this goes over the next few days. 🙂
stephen
NR5103E have same issue, worked for 2 days 5g 200mbps 50 up great until 2 days later and no 5g poor 4g speeds atrocious signal bars red green red not blue as before, in 3 5g app live signal strength went from fair to poor o er and over, 5g and 4g in my home is perfect and other devices 5g4g worked fine. onto 3 for over 3.5 hours and just today was told box fault and replacement coming tomorrow. NR5103E did make a popping sound and trouble with signal followed,
Hi @stephen,
This definitely sounds like this could be a hardware rather than software issue for you. Please let us know if you're running into any similar issues with the replacement though.
stephen
hi, replacement recieved today and all ok so far. S
Hi there.
Sorry you're having issues getting the router onto 5G. The b10 software is generally what enables this to work. The router normally updates automatically overnight when idle, and then reboots.
Can you confirm if the router has done this since you posted?
BigBoss
It's been a week and there's no B10 update yet.
Hi @BigBoss,
This is really odd, my understanding is that this is an automatic update. Sorry if I'm asking you to repeat anything you've already done, but just to confirm have you tried rebooting the router, leaving it switched on overnight, and if those fail a factory reset?
Let me know if none of that seems to force the update.
BigBoss
I have done all of that. In fact factory reset it twice I believe. Nothing prompts the update.
