on 10-29-2022 10:05 AM - last edited on 11-25-2022 02:55 PM by JonathanB
on 11-14-2022 08:47 AM
Hi Pete
cant find the message link to view your PM - I'm a newbie , can you advise where it is please lol
on 11-10-2022 03:22 PM
Hi everyone,
I know you're all really keen to get an update, and this is clearly causing a lot of disruption. We're not yet clear on if this is an issue on Sky's end, ours, or even some combination of both. Regardless, we want to do everything we can to solve this.
I'll send each of you a private message to put you in touch with colleagues that can correlate this issue reported on community with your actual Three accounts. From there, they'll be passing info onto specialists that can investigate behind the scenes.
I'm sure if we all work together, we'll get this figured out and fixed soon.
Thanks for your patience,
on 11-14-2022 06:26 PM
@JonathanB maybe a solution would be for three to roll out updates that change the dns of their routers to 1.1.1.1 or enable people to change it themselves, its seems the dns is the issue. Just a thought 🤔
on 11-12-2022 12:27 AM
ive also just started getting the problem, sky Q connected by ethernet to a Three 5Gmodem, connection to router fine, but no internet connection, then a few seconds later internet, the again none, cycles continuously , resulting in failed downloads. ( and intermittent no apps nor home)
good download speeds , Netflix on smart tv, on same ethernet, is fine.
on 11-12-2022 07:04 PM
Hi, Stevekn.
It doesn't sound like you're having much luck with it either. The issue is something that's currently looked into, I'm hoping there will be a solution soon.
To help the team investigate, I'll send you over a PM with some details of what to do next.
on 11-12-2022 03:16 PM
Exactly what I am experiencing, esp with the cycling of the connected to internet status
on 11-10-2022 10:02 PM
Hi there, I’m another Sky Q user with this problem, keen to get it sorted!
on 11-20-2022 05:58 PM
I’m Sky Q too. 4 months of no problems, then tried everything with Sky and 3, for 5 days now, and connection problems not sorted yet. In the sky settings menu, the connection drops off after 5 seconds then reconnects. This is continuous, so I’ve told 3 that if it isn’t sorted out by 21/11 that I will cancel, s the service is not fit for purpose.
on 11-11-2022 03:12 PM
Hey @gromit2468,
Thanks for letting me know, I'll send you over a private message so that we can get your info added to the investigation. The more examples we can share, the easier it'll be to figure out what's causing this.
on 11-10-2022 08:58 PM
May have spoke too soon, I get a few sticking at adverts , the adverts just play in a loop , restarted program and it’s running again ….
