Three Home Broadband: Zyxel NR5103E drops connection and WILL NOT RECONNECT AUTOMATICALLY
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
on 20-03-2023 03:47 PM
Extremely frustrating - every time it rains, the router drops connection and DOES NOT RECONNECT automatically. It has to be rebooted manually, which you can only do from home.
If you're away from home and rely on your home broadband to monitor your home and your pets, you're screwed. This needs to be fixed ASAP.
- Labels:
Anything else
Home Broadband
Wi-Fi
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 15-08-2023 09:23 PM
hi @JonathanB , i dont thing the change was done on the router, because:
- i check the APN and the wan setting before and after the talk with the support team and there was no change.
- i did manually change it to ipv4 explusively, then to ipv4+ipv6 and the speed was the same
- i did a factory reset on the modem just in case, and did all the manual change below including the apn address and ap IP version and still the speed was the same.
Only afthe the second chat with the level 2 support. i managed to regain the speed.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 01-09-2023 05:40 PM
I did a quick test today, by changing the APN from 3internet to three.co.uk, and I'm able to get my speed back, so is not an issue with the modem or with the mast/antenas is three internally that are restricting the trafic.
The issue is that i need my public IP so i cannot use three.co.uk for day to day usage.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 27-06-2023 01:55 PM
@456 Maybe you can purchaed it from amazon and try it? https://www.amazon.co.uk/ZTE-MC801A-HyperBox-5G-unlocked/dp/B095XC8S38
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 28-06-2023 04:10 PM
Thanks for that, but NO WAY IN HELL am I spending £200+ pounds on a router in addition to what I already pay Three. I can't afford that, nor should I have to. 😢
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 28-06-2023 04:54 PM
I have PM you
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 27-06-2023 01:45 PM
Sound like NR5103E are hardware issues then? Three should suspended NR5103E and revert everyone to have ZTE MC801a 5G router instead.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
27-06-2023 01:15 PM - edited 27-06-2023 01:19 PM
Finally got rid of the Zyxel and replaced it with a ZTE MC801a.
Immediate connection to 5g with ZTE (Zytel kept trying to lock on to 5g but couldn't so back to 4g+ then tried 5g again, and I assume that the constant switching between them caused the frequent disconnections.
1 week with ZTE so far excellent
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
27-06-2023 01:49 PM - edited 27-06-2023 01:53 PM
@NT306What firmware is it for ZTE MC801a? Is that right model number are:
ZTE 5G CPE MC801A?
Also do this router have band locking?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 27-06-2023 01:40 PM
Hi! How did you manage to get a ZTE? Did Three provide it?
Good to hear it's working better for you!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 29-05-2023 04:46 PM
Mine disconnected again this morning. Its at least once a week. Weather is great. Mast is about 160 metres away. It just stopped working dead. Signal on router showed full even while not working. Rebooted and working again.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 30-05-2023 11:29 AM
And Three keep telling me it's only happening to me...
