on 01-03-2023 08:45 PM
Hi there,
Sorry if this is something that has been raised before. I have a ZTE mc801a... It's been working fine for a few months without issue...
We woke up yesterday to find that all of our Google home devices, Google TV's and Amazon Alexa devices had lost connection.... The Google devices are connected but can't get through to their respective servers (Google's answer not mine)
After basically disconnecting everything..resetting it and reconnecting it one at a time... It appears to be the router... If I take the SIM out put it in a phone and turn on a hotspot the devices will work ... Put that same SIM back in the router and connect a device to it... The issue reappears...
The only thing I can think of is a firmware upgrade to the router but can't see why it would specifically affect those devices ... My phone and tablet and computer all still work ....
Any help would be much appreciated... It would be nice to watch TV this week!!
on 02-03-2023 02:06 PM
Hi everyone,
I'm sorry to hear about all the disruption you've been facing with these devices the last couple of days. I've passed on feedback about these issues, and we're looking into what would be causing them.
In the meantime, there may be a workaround that has helped users that were experiencing issues with connecting their PS5's that started around the same time. So it's worth trying the solution on the thread: PlayStation network won’t sign in on hub
If you do try this, please let me know if it works and what devices are affected.
on 09-11-2023 11:10 AM
I have just changed to the ZTE MF286R 4G router and am getting the same problems: Alexa Dot not connecting to WIFi at all, Certain LG TV Apps not connecting to their servers (Netflix and Tube)
on 09-11-2023 11:40 AM
Logging in to the router I see the APN is 3internet do I need to change this? If so I would like some step by step guidance please. Also note a thread on Amazons forum showing someone else with the same router and same problem on 5th Nov 23
on 17-09-2023 01:49 PM
Yup, killed my connection to Plex a while ago.
Three. Say no more.
on 13-06-2023 06:10 PM
I’m currently having this issue
on 05-03-2023 10:53 PM
Hi.
I'm experiencing exactly the same problems. Smart speakers and TV affected. The technical support has no idea and they blame the TV. Not sure how they came to this conclusion when there are more devices not connecting. They just don't listen.
on 06-03-2023 11:35 AM
Hi Roxie,
I've sent you a private message to direct you to more help with this.
To view your private messages on the community. Click on your avatar image in the top right of any community page, then "Messages"
on 17-07-2023 07:39 PM
Hi I am having the same issue
on 18-07-2023 04:36 PM
Hi @GnortsMrAlien,
Do you still have the ZTE MC801A router?
There's been a couple of recent issues reported with our other 5G router, the Zyxel NR5103E, so you may find some helpful info in New B14 Firmware For NR5103 has broken UPnP / Gaming! and FYI : IPv6 Prevented VPN Connection
on 15-04-2023 12:57 PM
I am also having the same issue.
