on 16-08-2023 05:06 PM
on 19-08-2023 08:03 PM
What gadget are you using ? There have been some reports of the last firmware update on the NR5103E causing issues. Are you using 5g broadband or mobile data on your 'phone ?
on 17-08-2023 08:19 PM
Check the network status for your postcode. Could be maintenance or a fault with the mast in your area.
