on 28-02-2023 02:44 PM
Hi, feel like I’m hitting my head against a brick wall with support. Had the 5g home hub for 2 months and no issues (only get 4g though in my area), suddenly today PlayStation won’t sign into my account. Initially thought ps network is down, no one else reporting it, reset router, PlayStation etc. no joy, then tethered PlayStation to my iPhone 12 mini (also with three on 4g).
Support literally don’t even understand the issue, saying issue is my end when proved it isn’t by signing in no problem tethering to phone, every other device and thing works at home; internet Netflix etc….so what. Have three changed to make this break?
thansk
on 01-03-2023 01:24 AM
If anyone cares, I figured it out finally by googling 8.8kbps as I knew this was the problem.
so using these search results from Google:
https://community.three.co.uk/t5/Network/Three-APN-Settings/m-p/5373
i changed the APN settings in the hub admin page from the address 192.168.0.1
If you’re on a mobile device you need to change the webpage from mobile to PC view then in the centre of your page you will have a title of “my router”, 4g+ should be toggled on then choose settings, then the bottom option APN. Then from mode auto to manual, and basically I added a new profile, named it 3 (though it’s just a name so doesn’t matter), PDP type is defaultly selected at IPv4 then in the APN field I just typed three.co.uk, authentication is none and username and password is none.
Hope this helps someone, my question is now why did this just suddenly happen today? Will this change again in future? And why don’t support have a clue about it at all, and try to blame me or Sony when it’s obvious it’s not the problem, since I told them repeatedly I can use the PlayStation with other internet sources. Goodnight!
on 01-03-2023 12:14 PM
thank you so much it worked right away
on 01-03-2023 12:20 AM
same issue, very frustrating. disappointed with lack of response from three.
on 01-03-2023 12:59 AM
Oh really, since when? Today is when it happened to me? Just tried some more troubleshooting and my speed test is 54mb down and 8.8kbps upload!!! Yes you read it right, 8.8kbps and it’s always been exactly that today, must be a bug somewhere in the router? Please someone at three acknowledge this tomorrow, glad it’s not just me at least but we need to figure out a way to fix it. Let me know if you figure anything out please
on 28-02-2023 06:56 PM
Have now tried literally everything, port forwarding, putting the PS5 in a DMZ. Wireless and wired, changing DNS settings, I can even watch streaming apps on the console whilst not signed into PlayStation network, sky go app, YouTube etc….
the only thing I can’t do is sign in online and play any online games, but tethered to the phone works perfectly. Honestly what has happened here? There has to be a reason
on 28-02-2023 03:31 PM
Sorry wasn’t very clear, should have said tethered the PlayStation to my iPhone and works instantly, basically the only thing that has stopped working is PlayStation network whilst using the hub and it’s incredibly strange only this would break.
