on 21-07-2023 07:27 PM
It's been a rough 2 weeks!
I've tried everything from resets, DNS, factory reset, changing APN, but it seems from the last firmware update I've lost all connection to the PS5 and randomly the Ring Doorbell Chime. WLAN / Wireless / 2.5G / 5G do not work!
I can't be the only one?!
I'm literally posting on here as I've exhausted every other option other than installing the firmware provided by the hub manufacturer and breaking any kind of support/warranty if I brick it!
Please help, or let me know where I can pick up the previous firmware, to see if that fixes this bug?
Thanks! B
on 22-02-2024 07:19 PM
Same issue my PS5 is not connecting, fails the internet connection test continuously??
on 23-02-2024 12:50 PM
Hi BigP
Sorry to hear you're having issues with this. We'd recommend having a look at this post here to see if this helps!
Danni
on 01-02-2024 09:45 PM
Hi Benjamin,
Did you manage to find a solution? I’ve just literally started having this problem
cheers
on 24-07-2023 02:49 PM
Hey @BenjaminBubble
That's really frustrating!
It might be worth having a look over the following thread : FYI : IPv6 Prevented VPN Connection - Three Community - 14851
The steps outlined have had a lot of success and it seems that you're having a similar issue.
John
on 21-07-2023 07:52 PM
I can't help but please add router type, firmware version, basic settings as these will help others help you.
