5G Broadband Drastic Speed Drop & Throttling to 120mbps after Settings Changed by customer service!
Mattyk66
I have replied to other peoples posts multiple times about this but thought I would start another post as well to keep up the pressure on Three as they are refusing to admit they are throttling connections, yet multiple users have posted on the community site about this and stating they can now only hit 120mbps download when they used to hit much higher, these are different people in different parts of the country, being impacted exactly the same.
I live right next to the 5G mast in my area, literally 30meters away. When I first went with three 5G broadband in October 2022 and up until November 2023, I was hitting anything from 600 to 900mbps download, all the time, even peak hours, I still have all the results recorded on my Ookla speed test app/account on my mobile phone.
In November, Disney plus stopped loading on my TV stating I was out of region, nothing I did/changed could get it to load so contacted three to see what was going on, they advised they could fix the issue by making some changes to my account settings and to restart my router and try and open Disney Plus again on my TV. Sure enough Disney loaded after the they messed with the settings, but from that exact point on (14/11/23) my download speed is stuck at 120mbps, won't go any higher. It jumps sometimes to around 400mbps when the speed test initially starts and then immediately and dramatically drops down to 120mbps with a second or two and stays there, clearly this is throttling and limiting the download speed.
I contacted them on multiple occasions over the next few months and they were giving me all sorts of excuses and said they had changed settings and to try again, and another said they were working in the area but it would be back to normal in a month. I ran a speed test every week and nothing has changed, stuck on 120. I have had a month refunded and a month half price but all this time they are still claiming they do not limit the download speeds which is obviously absolute rubbish.
As someone else has mentioned on the community site, when I do a speed test on my phone when I am not connected to the Home broadband, and I'm also with three for my mobile contract, I still hit the usual 500mbps+ and nothing has changed with the speeds on my phone, just my broadband from November onwards.
At the time I googled and couldn't find any posts on this so thought it was just an issue in my area, but after a speed test earlier, stuck on my 120, I googled and found this. Now I know this is happening to others I am going to contact them again and keep up the fight! Since I originally posted this only a month or so ago I can see there are new posts popping up weekly from people experiencing the exact same issue, so it seems to me Three and rolling out this download throttling across the country now.
For those that want to leave three, due to the speed decreases, who are stuck in contract, they agreed with me that I could leave with no charges due to the change in service. When you first sign up, you get 14 days no quibble trial to see how it works and what speeds you get and you can send back if you not happy. So, if the speeds you are getting now, do not match the ones when you first got it, you can argue this and say you want to leave without a charge!
A further update to this - I made three send me out a brand new replacement router only 2 weeks ago at the start of Feb 24, so I could rule out that being an issue. I have a brand new replacement router (Zyxel NR5103), brand new sim card, and nothing changed. exactly the same and stuck at 120mbps. I have attached screenshots of speeds tests below and you can clearly see the moment they made the changes at their end on the 14/11/23, and from this point on my speed has been throttled to 120mbps, when the speed only 3 days before that was 544mbps.  I have also added screenshots of speed tests from Feb 2023, compared to speed tests from Feb 2024 and the differences are striking. My speed used to vary, as non throttled speeds should, between 400mbps up to 900mbps depending on the time of day/load on the network, as you would expect. Now, my download speeds have no variation at all, 7pm on Saturday evening at peak times, 120mpbs, 3am on a Sunday at the quietest time possible, still 120mbps. If speeds were not being throttled there would be a variation to the speeds I could hit. When I do the same speed tests on the Three mobile network when not connected to the home broadband, I get much quicker speeds, as previously mentioned, and I get the expected variation depending on the time of day. As I am about to post this, at 1:15am on a Sunday, I have ran a speed test on the 5G Mobile network and just hit 656mbps download, and then the speed test when connected to my home broadband, 119mbps, five and a half times slower!! Admittedly the upload speed was the opposite way around hitting 30.3mbps on mobile and 63.3mbps on the home broadband, but this again just shows that the speeds are being controlled and throttled. And again, I have attached the screenshot of this test below.
I would like someone from Three technical support team to respond and finally admit that they are throttling speeds on the home broadband now, may be they are doing this as the network is getting busier as more people have joined over the last 12 months, but they need to admit this and stop the lies.
Speed Test Results showing change in speeds on 14/11/23 immediately after Three changed the settings their end -
Three Home Broadband Speed Test Results Feb 23
Three Home Broadband Speed Test Results Jan/Feb 24
Speed Test Comparison Three Mobile 5G to Three Home Broadband 5G
80 REPLIES 80
Mattyk66
It's great they have fixed it. If I get any issues in the future, which hopefully I won't if they've fixed the issues, I will be coming on this forum and messaging the techs directly rather than attempting to speak to and contact the customer service
If I were you, I would go through to the Three complaints team, you can find them directly via the webchat if you search complaints. As soon as you speak to someone it automatically logs a complaint on record, and they will want to close the complaint. Explain what has happened and all the times you have called with the slow speeds getting nowhere and now Three have confirmed it was an issue their end all along and have fixed it. Say you're not happy it has taken this long etc...and I'm sure they will refund you some months rental. They did with me over the last few months.
Mattyk66
That's much better. If that remains the case, at least you have a good useable speed now. Frustrating though that people are having to mess with the APN and the majority of people would not know what an APN is or how to change it let alone that this might increase their speeds!
XLBully
Agree - its definitely useable now. Also JonathanB said they did something with the settings on their end for people capped at 120mb.
Yes - it's ridiculous that it just got changed without any notice...
I'll keep an eye on it. Thanks for your posts. Would have gone back and forth with Three support / complaints email otherwise!
XLBully
Seems much more stable today - and speeds much improved.
https://www.speedtest.net/result/15976046538
XLBully
So, decided to try my SIM card in another router, the previous Huawei one with the different APNs
It seemed to really improve the upload speed back to around 10mb (vs like the 1mb or 5mb max recently). But download speed is around 70mb.
https://www.speedtest.net/result/15973184021
Very confused.
XLBully
Mattyk66
Have you tried changing the APN yet?
XLBully
Definitely seems to have improved it a bit.
Last Three results (no pun intended), done moments ago:
https://www.speedtest.net/result/15972955340
https://www.speedtest.net/result/15970446184
https://www.speedtest.net/result/15970441772
And from the morning via VPN
https://www.speedtest.net/result/15969275446
https://www.speedtest.net/result/15969271330
They all cluster around the 120mb mark.
I remember getting like 500mb with my phone in 2022: https://www.speedtest.net/result/13448656954
And some results recently were as high as 200mb: https://www.speedtest.net/result/15898759149
XLBully
Going to try the APN tweak and see the results. Will report back.
XLBully
Suggest we pursue a class action? Having the same issue - Central London. Used to get like 300mb. Now down to as low as 20mb sometimes.
