on 22-10-2023 03:21 PM
on 20-11-2024 05:37 PM
Hopefully you got my DM @JonathanB - I messaged you yesterday but haven't heard back yet - one of the potential slots was tomorrow but guessing that might be too soon!
on 21-11-2024 09:18 AM
Hi @EDIflyer,
Yes message received thanks. I'm just waiting on feedback on which is most suitable to pull together the supporting teams, will let you know ASAP!
on 19-11-2024 04:33 PM
Or in my case, left for another ISP 🙂 However, I'm still following closely, as family are still affected, and remains to be seen what happens when my next contract is up to if ever resolved
on 18-11-2024 03:39 PM
Another check-in with no changes
The incidence of the error is still highly variable but it is still there
Have there been any changes for yourselves?
on 12-11-2024 09:24 AM
Hi Everyone,
Just a quick update to confirm we're still investigating. I hope to have some more substantial news for you soon. I've also passed on the info provided here about manual band selection in case it helps point to the cause or solution of these issues.
on 11-11-2024 01:20 PM
Just a delayed check-in due to a busy weekend
There have been no changes from my tests - Having Band B3 disabled does still lead to reduced instances of the usual error message in my tests
05-11-2024 02:08 AM - edited 05-11-2024 02:15 AM
Ok, I ran 100 requests to https://docs.pi-hole.net on bands B1, B3, B20 and B28 (the bands I can find listed for my cell tower). I looped through these bands twice. I cannot see anywhere that N78 is an option I can change, or is listed for my cell tower, but it is very possible this is just down to me not understanding how 5G infrastructure works.
The number of failures per 100 requests are as follows:
| Band | Run 1 | Run 2 | Average |
| Auto (Main: B3) | 24 | 9 | 16.5 |
| B1 | 26 | 35 | 30.5 |
| B3 | 28 | 14 | 21 |
| B20 | 37 | 10 | 23.5 |
| B28 | 32 | 9 | 20.5 |
The tower details are:
For me at least, and accepting that this is a very small sample size, I would say that these results fall well within the range of natural variance, and changing bands has zero impact on my issues. Note that I ran the tests in the following order:
which suggests that the fluctuations are down to other external factors rather than the selected band.
on 05-11-2024 05:26 PM
Band N78 is responsible for 5G speeds - Without it you will be limited to 4G speeds only
If you can access your router's setting directly, you should have an option to either change the bands directly and, if that is not available, an option to switch between 4G and 5G networks with Three's 5G network being the NR5G-NSA type due to also needing a 4G band to work
I have added the website you have used to my long list of websites to check and, if you have any more websites that usually have errors, please mention them here as some websites seem to be more error prone than others and for different users
Thank you for performing your tests
04-11-2024 08:29 PM - edited 04-11-2024 08:29 PM
another thing to test is the Screwfix iOS app, it will never load with the three broadband but will load Ok with my usual mobile data. This is not fixed with only using band B1
on 04-11-2024 08:37 PM
By any chance are you using the APN 3internet for your Three broadband? Sometimes that would cause issues for myself so I switched to using three.co.uk instead and it helped with some random errors however, all Three APNs do currently suffer from the PR_END_OF_FILE_ERROR issue
Additionally, is your phone using 4G or 5G? It may potentially be linked to that
Unfortunately I would need to update my phone to use that app and I can not do that at this time
