EDIflyer
559 REPLIES 559
torz77
I'm not sure it is becoming a wider issue.... just most people don't know where/how to complain.
Three's "customer support" is as good as useless on anything which doesn't involve resetting your router.
I've lived with it for long enough as I just assumed it was a "me" issue, and it would have been futile trying to deal with customer service for the aforementioned reason.
Fortunately I have a VPN and found that solved the issue quick sharp. If I hadn't got one, I would be royally screwed and it brings it's own drawbacks.... and why the hell should I have to use a VPN just to use my ISP reliably??
Ultimately, I didn't even know this "support" channel was here (loose term... I'm not sure failing to address an issue for the best part of a year can be described as support). I only found it because I finally lost patience and googled "Three PR_END_OF_FILE_ERROR", and here I am.
FWIW, I can tell you pretty much exactly when I first hit this issue. It was on or about 31/08/2023. I know this, because I initially took the issue up with the owner of the website that first displayed this behaviour... so, yeah. That's over a year now. Nice.
Ultimately, I would have ditched Three by now if I had any other choice. Sadly my high speed internet options are non-existant, so I have no choice but to support an abysmal company. The best I can do (and do do) is tell anyone and everyone that is even vaguely considering this service to look elsewhere. I take no pleasure from that. I take pleasure from getting the service I pay for.
If it helps any (ha ha,  good one!), this is what I get when I try to connect to this very page without my VPN active. I know this doesn't appear to be an issue that impacts anyone else, and may even not be related.... but not being able to connect to my own ISPs site without a VPN is pretty much the definition of tinpot
Midnight54
Established
Maybe not on scale, as you say, lot of people will be simply unaware and put it down to various errors on their phone, or when using the likes of Chrome its less obvious.  However it must have spread, I had 18months+ of zero issues, then its been a PITA ever since without fail, on sites and such used daily.  How far spread though is the question, and if by certain masts, or regions
What would be interesting, we know its not the devices themselves as people have had replacements/diff models(possible fw changes excluded), would be eg driving to someones local town that allegedly have zero issues with my router, and see if the issue is magically gone from my router when connected to their mast.  However, those that dont have the issue are unlikely to be reading on here either
bytespider
Like you GitHub is my main nemesis, especially ghcr.io. Most other sites I have visited have been fine in Chrome but I know Chrome automatically retries when it encounters the error, so perhaps I've just come to expect it and not noticed the retries
MP
Still seeing the issue, just wanted to include regular websites where the issue is repeatable for me.
  • duckduckgo.com
  • en.wikipedia.org
  • mynoise.net
  • pavlovia.org
Nameless
Established
Just checking in once again to see if there have been any changes for any of yourselves
I have been away so I have not been able to do my usual checks
EDIflyer
Same issue here - in fact have found a the work remote access site seem to be having issues even when I'm on my VPN which is frustrating!  I see there's been some media coverage on this issue too that may be of interest to folks - https://www.ispreview.co.uk/index.php/2024/09/three-uks-home-broadband-users-suffer-intermittent-con....
Really need to have this situation resolved, would be great to get a progress report on likely timescales @JonathanB ?
Midnight54
Established
For the forum page thats had significantly more posts than any others in its section you'd think there'd be at least some sort of regular updates on what they are doing or at least trying.  Instead it feels like there is maybe a token suggestion at best every couple of months and then silence, making people wonder if they are actively even attempting anything at all or just like "meh....not my job...pass it to the other team"
munk
Same as always. 😞  Not much more to add really.
Freddyx844
It's certainly getting a little long in the tooth, any website or service using SSL (possibly limited to port 443) has problems. I'm probably just going to upgrade my home router to something cable of a VPN at 500+mb so everything in the home just works.
MH2
I am using a 3 business data sim in an iPhone and have been getting the same SSL errors at times
