on 10-22-2023 03:21 PM
on 09-06-2024 05:54 PM
Can anyone test this site and try to download the fastestVPN app. I get the 'secure connection failed' error consistently but it does eventually download the file if I keep clicking or refreshing the link.
09-08-2024 11:28 AM - edited 09-08-2024 11:29 AM
The link to fastestvpn is https://fastestvpn.com/download/windows-vpn. I thought I added it to the previous post but it's not showing. This seems to be a good test to see if the 'secure connection failed' issue is resolved or not. Attempting to download the app almost always fails.
on
09-10-2024
02:14 PM
- last edited on
09-11-2024
11:06 AM
by
Visiting that link comes up with:
SSL_ERROR_ACCESS_DENIED_ALERT
which is different from the omnipresent SSL 'PR' error which is the key indicator of issues relating to the subject of this thread (network traffic being interrupted / causing stalling issues).
I *think* this site you're linking to might be the result of adult filters being turned on? I say this because if I try and access another site that I know is blocked due to adult filters (ie link removed ) then I see the same error.
Using a VPN to access either of those links (link removed or https://fastestvpn.com/download/windows-vpn ) results in service as expected (ie circumnavigates any / all Three traffic inspection/manipulation and sees pages / connections loading correctly)
on 09-11-2024 11:13 AM
Hi @munk,
Totally appreciate it's for illustrative purposes, but I had to remove one of the sites you linked from the post, as it relates to purchasing age restricted items. Thanks for the insight, that some of the instances of SSL error are adult filter related though.
09-10-2024 11:13 PM - edited 09-10-2024 11:14 PM
Strange that you get an access denied error. I don't have an adult filter enabled and get the following when trying to download the fastestvpn.exe from the link..
It does download if I refresh a few times.
on 09-11-2024 12:50 PM
Who knows, nothing is transparent or obvious with the filtering that they do, even if you have adult filters on I've heard stories of it kicking in for some people randomly. They should have properly crafted redirection error pages clearly indicating why you're being blocked at any given time if you are blocked. 😞
on 09-11-2024 06:22 PM
For me it kicked in randomly after a reboot. At the time was struggling to find my account login (because they changed the login section so had to reregister etc) - however on rebooting the router, the adult filter was back off again - strange one - tho the typical errors typically persisted while that session was active
on 09-08-2024 11:59 AM
A probable red herring, but the linked exe downloads fine for me, both Chrome and Firefox
The only downloads from a browser thing I can simulate every single time, over hundreds of files is using the real-debrid service
on 09-04-2024 08:24 PM
I haven't had any 'secure connection failed' errors for the last couple of weeks but instead some pages will randomly fail to load completely or pause for a while and then load as normal. Maybe Three made some changes in the background but the issue is not fully fixed.
on 09-04-2024 06:57 PM
Does everybody use the same NR5103E Hub, or are there various models in use?
