on 22-10-2023 03:21 PM
on 08-09-2024 11:59 AM
A probable red herring, but the linked exe downloads fine for me, both Chrome and Firefox
The only downloads from a browser thing I can simulate every single time, over hundreds of files is using the real-debrid service
on 04-09-2024 08:24 PM
I haven't had any 'secure connection failed' errors for the last couple of weeks but instead some pages will randomly fail to load completely or pause for a while and then load as normal. Maybe Three made some changes in the background but the issue is not fully fixed.
on 04-09-2024 06:57 PM
Does everybody use the same NR5103E Hub, or are there various models in use?
on 05-09-2024 08:40 PM
The issue is definitely not a router specific issue as I have tested on a ZTE MC801A and a Zyxel NR5103EV2 with no apparent changes
I would have tested on another router but it had a faulty SIM card slot - Something that may still be common amongst the routers provided
on 04-09-2024 06:43 PM
on 05-09-2024 08:28 PM
Sometimes I would experience similar issues when testing although I did not think too much about them at the time as it would happen quite often on the 3internet APN but very rarely on the three.co.uk APN (And iD Mobile's APN which I am now using)
It is likely related to the usual issue
on 03-09-2024 07:11 PM
Some days seem significantly worse than others needing to hit refresh half a dozen times for links to start working etc.
Another issue I'm getting is affecting work more recently....obviously work is generally on a VPN, but some things are split tunneled, and some of those that are are affected are causing a huge pain so I have to RDP to a server to then do some simple tasks instead
on 28-08-2024 08:53 PM
Recently I've also had issues with PS5 randomly failing to login to Playstation network when starting an online game such as Valorant which causes the game to give an error. I'm wondering if this issue is also related to this topic of this thread.
Ookla Speedtest is also occasionally failing with a 'network error' when attempting to perform a test.
on 02-09-2024 01:27 PM
Yeah. I was seeing this issue months and months ago but (maybe coincidentally) by introducing a mesh network in the house, it went away.
It's back with a vengeance now though - I'm seeing the same PS Networking issues this last 2 days to the point where I'm nearly banned for the season from Overwatch due to the number of dropped connections on game start.
Please sort this out. Whatever you're doing has suddenly made it much, much worse for me.
on 02-09-2024 07:13 PM
I also see that all the issues reported over the last 6 months or so by various users are now hitting me at once: really high latency when making a connection, inability to use banking apps reliably, stuttering when streaming from Disney+, SSL errors when using github,com and as mention above, connection drops when connecting to online games. I'm seeing that roughly 7 out of 10 Overwatch games disconnect when attempting to connect to the server which means I'm now banned until the end of the season (mid October). Great,
I'm obviously less than impressed.
Three - it's clear that whatever resources you're throwing at this are nowhere near enough. Unfortunately, It's obvious to us now that you _know_ this - any company that has an open issue with many customers affected for nearly a year makes a decision about how to progress with it and what resources to assign to it. Your current level of investment into this issue is a very deliberate choice and one that reflects very poorly on your commitment to provide a decent broadband service to paying customers.
You really really need to spend more time and resources on this issue. You clear
You obviously know that this is the case and have chosen not to assign any further r
