on 22-10-2023 03:21 PM
on 16-09-2024 06:12 PM
Still seeing the issue, just wanted to include regular websites where the issue is repeatable for me.
PR_END_OF_FILE_ERROR
on 15-09-2024 06:13 PM
Just checking in once again to see if there have been any changes for any of yourselves
I have been away so I have not been able to do my usual checks
on 15-09-2024 09:38 PM
Same issue here - in fact have found a the work remote access site seem to be having issues even when I'm on my VPN which is frustrating! I see there's been some media coverage on this issue too that may be of interest to folks - https://www.ispreview.co.uk/index.php/2024/09/three-uks-home-broadband-users-suffer-intermittent-con....
Really need to have this situation resolved, would be great to get a progress report on likely timescales @JonathanB ?
on 15-09-2024 09:55 PM
For the forum page thats had significantly more posts than any others in its section you'd think there'd be at least some sort of regular updates on what they are doing or at least trying. Instead it feels like there is maybe a token suggestion at best every couple of months and then silence, making people wonder if they are actively even attempting anything at all or just like "meh....not my job...pass it to the other team"
on 15-09-2024 08:01 PM
Same as always. 😞 Not much more to add really.
on 11-09-2024 05:02 PM
It's certainly getting a little long in the tooth, any website or service using SSL (possibly limited to port 443) has problems. I'm probably just going to upgrade my home router to something cable of a VPN at 500+mb so everything in the home just works.
on 09-09-2024 08:17 AM
I am using a 3 business data sim in an iPhone and have been getting the same SSL errors at times
on 06-09-2024 05:54 PM
Can anyone test this site and try to download the fastestVPN app. I get the 'secure connection failed' error consistently but it does eventually download the file if I keep clicking or refreshing the link.
08-09-2024 11:28 AM - edited 08-09-2024 11:29 AM
The link to fastestvpn is https://fastestvpn.com/download/windows-vpn. I thought I added it to the previous post but it's not showing. This seems to be a good test to see if the 'secure connection failed' issue is resolved or not. Attempting to download the app almost always fails.
on
10-09-2024
02:14 PM
- last edited on
11-09-2024
11:06 AM
by
Visiting that link comes up with:
SSL_ERROR_ACCESS_DENIED_ALERT
which is different from the omnipresent SSL 'PR' error which is the key indicator of issues relating to the subject of this thread (network traffic being interrupted / causing stalling issues).
I *think* this site you're linking to might be the result of adult filters being turned on? I say this because if I try and access another site that I know is blocked due to adult filters (ie link removed ) then I see the same error.
Using a VPN to access either of those links (link removed or https://fastestvpn.com/download/windows-vpn ) results in service as expected (ie circumnavigates any / all Three traffic inspection/manipulation and sees pages / connections loading correctly)
