EDIflyer
626 REPLIES 626
AlSeek
I have found setting the router in 4G only mode results in the error appearing less frequently than when in 5G mode, potentially could be related to the reduced speeds of 4G. Who knows ¯\_(ツ)_/¯
It does still happen in 4G mode though.
AkiTaiyo
Yep, was purely coincidence that I'd had a day without error.. about an hour after writing that post, back to errors again.
bytespider
I took get days where I think all is good and others where every other request gets EOF
AkiTaiyo
On the plus side, it looks like I can get out of my contract without any early leaving charges..
AkiTaiyo
Well, I've wasted more than enough time on support calls with people that just follow the same script over and over again, "reset the router", "the problem is with the app", "is the 5g light on"..
Time to change provider.
AkiTaiyo
Must also note that just changing DNS doesn't mean the problem goes away, theres nothing to say the resolver wont give you the failing location at some point in the future..
AkiTaiyo
Changed my DNS from my own resolver to use Cloudflare with Quad9 as backup.. No more problems with any of the sites I've been having regular issues with..
From my limited testing, these were all served from Akamai, but if wgen has also seen the problem from other CDNs, then a DNS change might not be a complete solution.
If anyone has a non-Akamai URL that fails regularly (I was using visualsudio.microsoft.com because it failed so frequently!), I can also test the URL through Three and other connections to see if is a similar issue with different data-centers.
bytespider
DNS did nothing for me. I've had some success with disabling IPv6 features including DHCP/RA but that's anecdotal as I've not browsed much to be able to notice of it's helped
AkiTaiyo
Yeah, the DNS change has only affected some sites.  I keep coming across more failing sites the more I browse.
I also have all IPv6 features turned off on the router.
bytespider
Can confirm, disabling all IPV6 features does not help.
