on 04-10-2023 10:31 PM
I'm having issues with my router - I have the NR5103E 5G Hub. (Got it today)
On my phone it is fine. However, when I connect to my xbox it doesn't offer me a decent connection. Loading time into games has increased, my ping has trippled to 90 and I spend ages on loading screens.
Connection Virgin provided me:
5GHz
IPv4
NAT Type: Open
All services are available
Whereas 3 provides:
Current network status
2.4GHz
IPv4
NAT Type: Moderate
UPnP not successful
xbox.com/xboxone/UPnP
Can anyone advice how to improve my connection for gaming? If this doesn't improve by the end of tomorrow I'll be cancelling my contract.
My firmware is version: V1.00(ACBJ.0)b14
on 03-01-2024 01:21 PM
My solution was to login to the router on 192.168.1.1 using username = admin and assigned password.
Select Broadband
Select Cellular APN
Select the first APN Setting and click the pen and paper edit button.
Click the APN Manual Mode
change the 3internet to three.co.uk
click OK
on 16-04-2024 11:20 PM
This hasn’t worked for me
on 09-10-2023 03:01 PM
Hi @Mr_RSVR,
Have you tried searching for UPNP in the router settings and switching this feature on? It's also worth comparing the performance with a wired connection as this tends to be much more stable for gaming.
Let me know if either of these suggestions help.
on 06-10-2023 10:57 AM
on 24-05-2024 08:44 PM
You’re joking right? 😂
