on 22-10-2023 03:21 PM
on 10-10-2023 11:39 AM
Hi All --
I've been using Home Broadband with a NR5103E router for less than 2 weeks and I'm having some issues.
From time to time, I'll get the error below in Firefox (also happens in Chrome but it retries automatically). For general browsing it is mostly annoying but I can live with that. However, it gets really frustrating when running servers locally that can't connect to remote services.
Things I've tried already:
- splitting 2.4 and 5
- connecting a separate router via cable
- using Google's DNS servers
An error occurred during a connection to www.skyscanner.net. PR_END_OF_FILE_ERROR
Error code: PR_END_OF_FILE_ERROR
The page you are trying to view cannot be shown because the authenticity of the received data could not be verified. Please contact the web site owners to inform them of this problem.
Has anyone experienced this? Any ideas on what I could try?
Many thanks in advance!
ps: Current Firmware Version: V1.00(ACBJ.0)b14
on 24-10-2023 07:20 PM
I am experiencing it all the time, especially in the evening when I am using the internet at home most. Sometimes I need to force the refresh 3,4 times before the page loads up correctly.
I'm concidering leaving and switching to another broadband. I was very excited when I got this one but the constant error starts to testing my patience.
I live very close to the 5G masts and once the connection is established the internet is blazing fast, but it needs that push and plenty of services keep breaking because of that connection issue.
K.
on 25-10-2023 01:17 PM
I've stopped using it in the evenings - the speeds drop significantly. I am too at odds whether to keep it or not, as I was looking for an alternative to my regular provider which for now is A LOT more reliable. VPN helps, but I can't use with chromecast, for instance..
on 24-10-2023 08:36 PM
@elkolesio thanks for posting, good to know that @tucu and I aren't alone!
We've also been discussing this in a thread that I started - https://community.three.co.uk/t5/Broadband/Intermittent-connection-issues-loading-changing-site-secu...
@JonathanB would you be able to merge the two thread?
@elkolesio would you be able to try connecting via a VPN and see if that helps? It made a significant difference for me and might help troubleshooting. Also are you on LAN or Wi-Fi? (I've seen in on both but might still be interesting to know).
on 25-10-2023 05:30 PM
Yeah best to keep one topic when it's the same issue. @tucu thanks for spotting this first. I've made the more recent thread by @EDIflyer the main one, just for visibility more than anything else as yours has sunk down the list a little.
on 25-10-2023 01:19 PM
LAN made no difference at all in my tests. I've tried that, splitting the 2.4 and 5ghz bands, disabling one, etc, etc.
on 25-10-2023 01:13 PM
Agree with @EDIflyer -- issue stops when using a VPN (I'm using Mozilla VPN). I wonder if it's related to the latest firmware? I'm using Mac, FWIW..
on 25-10-2023 02:02 PM
There have been a couple of issues reported relating to our IPv6 rollout, which was the most significant change on the last firmware version. It was interfering with some VPNs, and some devices connecting to the router.
FYI : IPv6 Prevented VPN Connection includes a bit more info and a couple of users have documented how to change the APN profile to manual and to set up IPv4 only. So it may be worth a check if this still happens when the router is set to the older IPv4 only set up.
on 25-10-2023 10:23 PM
Thanks @JonathanB - I've had a look at that thread and tried switching the APN profile to manual but no change - still lots of errors (examples below)...
- OpenSSL SSL_connect: SSL_ERROR_SYSCALL in connection to github.com:443
- "Head "https://ghcr.io/v2/home-assistant/raspberrypi4-homeassistant/manifests/2023.10.5": Get "https://ghcr.io/token?scope=repository%3Ahome-assistant%2Fraspberrypi4-homeassistant%3Apull&service=...": EOF"
- aiohttp.client_exceptions.ClientConnectorError: Cannot connect to host portal-ww.ecouser.net:443 ssl:True [None]
on 24-10-2023 06:01 PM
Thanks for the reply, Jonathan. I'm on iD Mobile and I've not noticed it on my phone when on the mobile network, only when connected to my Three Broadband router. I've also not seen it at other locations with my laptop so it does seem to be a router issue. I must confess I don't recall experiencing when I first got Three about 4-5 months ago, I'm not sure if anything changed in the update a couple of months ago? The way it stops happening with the VPN is also really interesting. It's also not Windows-specific as I've got a Pi 4 on the network running Home Assistant and it has been having issues doing updates - I've then realised if I keep just going 'retry' it works, a bit similar when connecting to Github!
