EDIflyer
632 REPLIES 632
applepieman
Been away for a week and hoped this would be resolved by now but appears not. I am struggling to understand how progress hasn't been made in all this time. Can we have a proper update on this issue and when a fix will be provided as it simply isn't good enough carrying on like this
tucu
FWIW I swaped my phone card with the router card and set the APN back to 3internet. Still getting errors when running @EDIflyer's test
for i in {1..100}; do curl -I --no-progress-meter -o /dev/null https://github.com || true; done;
hughesceri
I don't know if things are getting worse for me or whether I'm relying more on github.com and ghcr.io urls than previously, but my Three home broadband is starting to become unusable for anything related to software development now.
Even the simple act of updating or installing a package using homebrew on the mac is very difficult, as each of the (many) dependencies for a package requires a couple of hits to ghcr.io and when one of those fails I have to rerun and rerun until it works - or like I've had to do today, go to a place with public wifi and run it there.
How long can we expect this to continue? If there's no sign of a workaround, how long until Three starts to really acknowledge the issue and give us something that can help, e.g. some sort of paid VPN service.
Apologies if this is not the relevant forum to start a conversation about compensation etc - I'll happily try something else that doesn't require any form of subscription / payment, but I'm not going to use a limited, free VPN as that's just a short term workaround that will eventually hit a data transfer limit.
applepieman
This really is quite disappointing I have to say and generic technical guidance really isn't the answer for customers.
BrummyGit
I got fed up with the problems as I need a reliable and fast connection, therefore decided to try an expensive fix. I bought myself a Zyxel FWA710 5G outdoor router and mounted it in my loft next to the Three supplied NR5103E, then swapped my SIM over.
For the last week running with the FWA710 using the latest OEM firmware and IP Passthrough mode I haven't experienced any issues other than a loss of service overnight at the weekend that I suspect was mast maintenance as it started at exactly 2am and lasted an hour.
Hey everyone,
Sorry for the delay in updates. The support teams on our side haven't been reproducing the issue, so it does seem to be quite elusive. We're still digging deeper into what could be the common link for those of you who are affected.
There's a few potential causes in terms of cached data, DNS settings, Firewalls, etc, here's a couple of guides/suggestions for related errors:
https://kinsta.com/knowledgebase/err_connection_closed/
https://kinsta.com/knowledgebase/pr-end-of-file-error/
Please feedback if any of the suggestions in the above articles help with this issue.
I'll let you all know as soon as we have any more to share on our side.
AlSeek
Thanks for the update @JonathanB. I've tried all these suggestions but no difference for me. Also tried the DNS flush suggested by @EDIflyer but soon had the usual error on affected websites. TBH I don't think it makes sense to be a local device issue since, as mentioned in the past, switching my router to use 4G only pretty much resolves the issue besides a very rare instance but 5G is extremely badly affected, if it were a local device issue of DNS cache or otherwise I'd expect similar incidence on 4G and 5G. (I have primarily been using 4G this last month besides occasionally going to 5G to check if it's still an issue, which it severely is).
EDIflyer
Thanks for the update, @JonathanB .  It's quite disappointing that the engineers haven't been able to replicate it given how many of us has posted re issues.  I had a look at the links and most of them seem very generic and not necessarily applicable as they are referring to Chrome/Firefox when a lot of us have also confirmed the issue on mobile phones (on WiFi), smart TVs, headless Linux devices, etc.
However one of the later solutions was more interesting - re flushing the DNS cache. I followed the more detailed guidance at https://devconnected.com/how-to-flush-dns-cache-on-linux/ as well as the Windows guidance at https://kinsta.com/knowledgebase/flush-dns/ and when running the code from @Tatablack from upthread (slightly adjusted below) I've noted a marked improvement with no errors after 100 curl requests:
I'm not certain it's 100% sorted yet but I'm going to try running things without the VPN for a bit and see how I get on (although for shop check-outs I might still pop it back on for a bit just in case!)
tucu
Tried this, made no difference. It was better for a few days when I switched APNs, but the problem is still there. Interestingly, the error is different for me:
curl: (35) LibreSSL SSL_connect: SSL_ERROR_SYSCALL in connection to github.com:443
The fact that a VPN fixes the issue AND that @BrummyGit still had issues with another router makes me wonder what kind of networking monitoring does Three do 🤔 (I did try disabling the adult filter as suggested in another thread - made no difference either).
EDIflyer
Just to update - still seeing it occasionally, albeit much less than before...
curl: (35) OpenSSL SSL_connect: Connection reset by peer in connection to github.com:443
