on
29-10-2022
10:05 AM
- last edited on
25-11-2022
02:55 PM
by
on 21-09-2023 03:13 PM
Hi @shbishop86,
We've seen a few device connectivity issues like this popping up recently. Can you let me know if the advice on changing to a manual APN on IPv4 as described in this thread helps: FYI : IPv6 Prevented VPN Connection
04-08-2023 08:22 AM - edited 04-08-2023 08:22 AM
@JonathanB This issue is still going on for lots of customers trying to use Sky services over their Three broadband - it's just not acceptable... Three support are just useless and ask you to reboot, remove "too many devices", and eventually blame the Sky equipment and give up.
This is a service people are paying for and not able to use. There is something in Three's network that just blocks Sky content - I cannot work out what it is but Three should have their network team working on this.
If this cannot be fixed, I need to go down the route of cancelling my service as it's currently not fit for purpose
on 01-08-2023 03:15 PM
Hi all, this is my first contribution here, as I have been suffering withe THREE/SKY issue.
The issue for me was sudden and it happened 3/4 weeks ago when THREE were working on engineering over a long weekend.
Since then I have tried every solution I could fine but alas still no change. My personal view is that this is about SKy Q not working over the THREE network.
In general my Sky and Three work fine just not together. I had a Sky engineer visit klast week, was here for a few hours but was unable to fix it.
I am at the point where I need to do something likje change from THREE or try Sky Stream but do not know much about it.
Thanks to all contributors afore me.
Cheers
Alan
on 02-08-2023 03:16 PM
Hi Alan,
The timing of this may coincide with some issues that have popped up on this thread FYI : IPv6 Prevented VPN Connection although the thread was initially about VPN issues, there's some suggestions on there that seem to be helping with some smart device connections too.
It may be worth trying setting your APN mode to manual, with APN 3internet and IPv4 only, there's more info on the thread I linked. Let me know if that seems to help.
on 05-04-2023 11:06 AM
Also having same issue with Sky content - I'm using the Xyxel NR5103E router
on 21-04-2023 03:22 PM
Hi @brassic_lint,
Sorry for the delay in replying. We've not made any changes on the Zyxel recently that would account for this. Is it definitely only an issue with Sky streaming, or are you having any issues with other services or your speeds etc?
on 23-04-2023 04:24 PM
I’m a new user, so I don’t know if it was caused by any update; but everything works perfectly except Sky content.
My general setup is having the router in bridge mode into my network, everything works if I flip back to my Sky DSL connection.
However I’ve also tried connecting the Sky box using direct WiFi to the Zyxel cutting out the rest of the network Using factory default on the Zyxel.
It’s 100% an issue with content over the Three network, I would guess it’s not the Zyxel either as I have the same result when routing features are disabled and it’s in bridge mode.
on 05-05-2023 04:07 PM
Hey @brassic_lint,
Sorry for the delay in getting back to you. With the previous issue this thread was originally about, many users found that changing the DNS helped. I believe 1.1.1.1 and 8.8.8.8 tended to be successful, have you tried this change? Have you been in touch with Sky about the issue, if so have they been able to identify an issue?
09-05-2023 10:54 AM - edited 09-05-2023 10:55 AM
Hi @JonathanB
I already use 1.1.1.1 as primary DNS & 8.8.8.8 as secondary (I have also tried many combinations, but this configuration does work with the Sky DSL too)
Sky state that the issue is with the ISP since it works through Sky DSL, and not through the Three 5G. In the meantime I have also tested with a (4g) connection from O2 which works.
Unfortunately the issue *must* lie either within the Zyxel router, or the Three network. I have eliminated all other options now.
on 16-03-2023 08:47 PM
I seem to have run in ti this same problem again. My contract is due up soon, because of this ongoing issue, I'm doubting as to wether I should renew.
