on
29-10-2022
10:05 AM
- last edited on
25-11-2022
02:55 PM
by
on 21-03-2023 01:12 PM
Hi @kevgals,
I'm sorry to hear that you're running into these issues again. As I recall you're using the ZTE MC801A, have you received the B15 firmware update in the last few weeks, and if so does that line up with when this issue came back?
on 22-03-2023 08:07 PM
Hi Jonathan, yes I have the B15 firmware. Not sure when it updated. Strangely the problem doesn't seem as bad this time. Some things download immediately, some take few tries and some not at all. I'm trying to establish a pattern, I'll let you know if I succeed.
on 29-03-2023 04:37 PM
Hi @kevgals,
Yeah I've seen a few instances of a different issue recently. In this case it's not limited to Sky, but seems to affect certain smart devices and streaming services since that B15 update.
I've sent you another private message, if you can chat with the team linked there, they'll get this raised with a tech team that ought to be able to fix this.
on 04-04-2023 09:21 PM
Hi, I'm also having issues again with sky. It either downloads on demand content extremely slow or gets stuck and stops downloading.
Any help would be much appreciated 👍
on 21-04-2023 03:18 PM
Hey @webbz104,
Sorry for the delay in picking this up. I recall you've got the ZTE also, is this on the B15 software too, and did the issue seem to come back coinciding with that last update?
on 13-01-2023 04:15 PM
Hi everyone,
Sorry for the delay in updates on this. The issue does seem to now be resolved. If anyone is still running into issues with streaming from Sky devices, or if the problem seems to come back, please let us know.
on 27-01-2023 07:13 PM
I have literally run into the problem again this evening (27/1/23) after it working ok using a 1.1.1.1 dns
tried 8.8.8.8. no luck either
on 28-01-2023 02:10 PM
So, I resolved the above but not sure why it did resolve ..
Basically I use the Three Router / hub as the modem only -I then use an TP-LInk router which controls all my wifi and ethernet connections which connected into the Three hub, .
So I then connected the wifi of the Three Hub to the Sky Q box and its now working great.
This was not the cause of the original fault as i had previously tried this in the early days of the issue but to no avail.
Weird !
on 13-01-2023 09:55 PM
Just out of interest, do you know what caused the problem?
10-01-2023 07:59 AM - edited 10-01-2023 08:00 AM
This sounds very similar to the problems I encountered with the new Sky Stream service using the pucks. Frequent stuttering, failing to load programs etc. Reading some of the comments suddenly reminded me that Sky do say the service is geographically tied to your address, and wondered if their servers might be struggling to find your location via the 3 network?
