on
29-10-2022
10:05 AM
- last edited on
25-11-2022
02:55 PM
by
on 28-12-2022 07:47 PM
This is currently working fine for me. Does anyone still have this problem? @JonathanB has this been resolved or has it just gone away.
on 06-01-2023 02:45 PM
Everything seems to be working fine here too. Probably until the next router update then will probably go again🤣
on 07-12-2022 10:07 PM
@JonathanB Are there any updates on this issue. It's all gone quiet your end. Surely we all deserve updates and progress reports.
on 08-12-2022 11:54 AM
Hi everyone,
I'm sorry that it's been some time since the last update. Our technical specialists have been looking into this but they have not identified any issue on the Three network that would explain the situation.
We don't want to 100% rule out the possibility without making sure we've checked every angle though. We'd like to run some live testing with some of you.to see if gathering info in real time as you attempt to stream and download helps figure this out.
If any of you would be happy to take part in this testing, please use the chat link in my original private message to you, and the team will make sure that your Three accounts have up to date contact info, and we'll also collect and pass on the best times for the technical team to contact you for carrying out the tests.
on 09-12-2022 11:20 AM
I'm not understanding why they haven't managed to find a solution yet. It must be an issue with the dns that three use because for those that have been able to change it to 1.1.1.1 everything works fine.
Why can't you just simply update the routers with the dns of 1.1.1.1?
on 08-12-2022 09:25 PM
Happy to test
02-12-2022 08:23 AM - edited 02-12-2022 08:24 AM
It seems to have been resolved.
Yesterday saw reports of same on the Sky forums.
I had to unplug and reboot the Sky Q (which also reset the DNS to 168.x.x.x. from the 1.1.1.1 or 8.8.8.8 I had previously set in an attempt to fix
Currently the box is using wifi to the three 5g router, following various fix attempts from the Sky engineers. When I have time I will experiment to see if it still works on my old set up which is: ethernet to the Asus mesh (which in turn is hardwired to the Three router, which has wifi disabled.
Would be great to know roughly what was the problem and the eventual resolution, so that I can watch for it in future.
Once it has been stable for a couple of days I will report back
on 03-12-2022 06:14 PM
Mine seems to have started working again too. I have a puk connected to a different 4g router than my glass tv is connected to, I haven't been able to change the dns on the 4g router so it hasn't been working but tried it today and all is working fine. I was just wondering what the benefits of changing the dns back on my mesh router? Maybe I should keep it on 1.1.1.1 incase it happens again?🤔
on 06-12-2022 10:07 AM
Mine started working and has now stopped working again ☹️
on 30-11-2022 10:22 AM
Just to add to this - it's not only Sky Q/Glass - the issue also applies to purchases/rentals made via the SkyStore - I have a number of movies I've purchased that way over the years, despite no longer having TV with Sky. Until recently I could cast these to my TV from my phone without issue - and now I just get an error message. I can stream the movies without issue on a different 4G connection, and reading this thread it seems that this is the same issue. This is on 4G Home broadband - @JonathanB can you add me to the list of affected customers so I get notification of any updates?
