on 07-12-2023 02:49 PM
Since 7.30 last night the transmitter has but sending out a signal with 1.3 go Dow load speeds and I bar for calls.
I know it’s the transmitter as I have 5 devices all saying same thing. Also my Mac traced the issue back to it using diagnostic tools. All the rebooting in the world won’t make a difference if the issue is the transmitter.
we had an issue week and half ago caused 50 mile an hour winds which was fixed but I think the freezing fog -5 has caused another outage.
I have tried in vein talking some idiot on the chat and phone and now completely fed up
just fix the dam thing
on 07-12-2023 07:05 PM
Now fixed thank you
Now fixed thank you
on 07-12-2023 03:23 PM
With respect I fail to understand what the point is of this post when you’ve already commented on it yesterday unless it’s a case of needing to vent your spleen. As frustrating as it is (that part I DO understand) it won’t be fixed any quicker by repeated similar posts on here.
on 07-12-2023 03:02 PM
I hope it's an easy fix.
